メインコンテンツにスキップ
The HP Pavilion 15-ba003ds is a laptop with a navy blue case color designed by HP. This device comes with a 15 inches LCD screen with a resolution of 1366 x 768 px display and a full-size keyboard. Model number: 15-ba003ds.
How to download google play app on pc
i would like to know the best and safest download app so i can play 8 ball pool on my laptop. please a safe and secure form.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
Hi @erickhdez1226,
Here's the Google link that may help.
Unless you have upgraded your laptop it probably won't work as according to Google, your laptop's specifications aren't up to the minimum system requirements needed by the app. Although if you do try, the app will tell you whether or not it can be installed.
Also if you did upgrade the HDD to an SSD and also the ram to 8GB it still wouldn't be that good because the GPU in the laptop (which can't be upgraded) is not as good performance wise, as the minimum recommended Intel UHD 630 graphics.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Erick Hernandez さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 88
