メインコンテンツにスキップ
2019年9月25日発売の第7世代iPad、32GBモデルと128GBモデルがあります。型番はA2197。
20回答 すべてを表示
Screen glitching after glass/digitizer replacement **URGENT**
Backstory, I'm no professional but have been fixing iPhone/iPod Screens since I was 8 years old. I've always been the go-to to fix iPhone screens but have only ever been self taught from iFixIt Guides.
Anyways - I have tried to repair only my 2nd iPad ever from a family member the other day with just the worst luck. Everything has gone wrong with this repair and I'm so stressed at this point, I can't afford to dump any money into this as I believe I messed this up on my own.
Firstly, I was only asked to replace the screen as it was cracked. Ok, easy enough. Worked on it the other day and finally after 4 hours, got it all back together and done. Went to put the screen on and didn't realize the frame was gashed and CRACKED THE NEW SCREEN.
Anywhom, I said whatever and bought a new one and went to go replace it.
ISSUE THAT I NEED HELP WITH BELOW
  • Did a function test with the old cracked screen and the newly cracked screen. All was working as should.
  • After installing the new screen(2nd new one) it is now found that the LCD screen is glitching.
  • It is that "Ghost Touch" and moves the screen around, types in random passwords ETC.
  • I thought maybe it was the LCD itself. Replaced that, did not fix issue.
  • I tried with old glass digitizer, this ghost touch glitching problem is still there. I know it's not the digitizer.
  • Even if my hands are off the LCD screen and it is ONLY the LCD screen plugged in, I'm getting this ghost touch issue.
  • Checked the board connectors and all pins seemed fine. From a visual inspection of the Micro PCB connections, all looked to have no issue. Do not have a microscope, as I'm NOT A PROFESSIONAL. This was only confirmed from a visual inspection.
I really appreciate the help and support, as I've been stressed and really losing it over this thing. Not really sure where else to go.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
1 件の回答
最も参考になった回答
Hi Bradley,
You're not the first person with this problem; go ahead and check out this previous question from another user with the same problems as you. There are quite a few possible solutions given, and hopefully one of them will work for you.
SOLVED: iPad doing its own thing! Ghost Touching - iPad 2 Wi-Fi EMC 2415 - iFixit
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Bradley Florence さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 5
過去 30 日: 11
今までの合計 278
