Home button ribbon flex
Hi all
In need of some help, I stupidly pulled apart the flex on the home button on this iPad 5th generation A1822, and need this to work again, can this be repaired, pictures attached.
Looks like you ripped the cable. Luckily you can use the iPad 5 Wi-Fiのホームボタンアセンブリの交換 guide and replace it. Since this is an iPad with a physical button replacing it will only loose Touch ID but the regular home button functionality remains.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 13
過去 30 日: 21
今までの合計 353
