メインコンテンツにスキップ
Now discontinued, the business-oriented laptop was released in October 2007, and can be identified by model number PP23LB.
1回答 すべてを表示
Can Dell Vostro 5502 Motherboard repairable?
I have Dell Vostro 5502 Laptop which is not working is it able to repair its motherboard?
https://www.xfurbish.com/dell-vostro-550...
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
ベストアンサー
Hi @moni1234,
It might be repairable depending on what's wrong with it as you only said - "not working", but that's not telling anybody much.
Does it show that the battery is charging for example, do the fans turn on etc.?
If it has been water damaged then the chances of fixing it are low to not at all.
Finding the schematics for the motherboard is a good place to start locating problems.
What is the make and model number of the motherboard which s printed on the motherboard itself (not the laptop make and model number)?
Knowing this will help to find the schematics if they're available.
If they are you will have to know how to read schematics and how to use a digital multimeter as well.
Here's the owner manual that will help you to disassemble it.
このアンサーは役に立ちましたか?
スコア 3
コメントを追加
回答を追加する
Moni1234 Moni さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 2
過去 30 日: 5
今までの合計 114
