Why is my phone not charging
お持ちのデバイス用の修理ガイドとパーツ一覧とアンサーフォーラムにアクセスする。
Troubleshoot your cable, charger, outlet & case
Check that your charger and cable work. Try them with another device. Check that the cable is securely connected to the charger and to your phone. Check that there's nothing in the port of your phone, like dust or lint.
Regards,
このアンサーは役に立ちましたか?
Most of the time but not all of the time it's because the charging port it's self is malfunctioning or broken, or the phone has been plugged in and used too much .when it's plugged in to charge the wiggling of the cord and the temperature of the plug over heating the port cause it to lose connection and stop working. And like most people I've talked to like their phones but have no clue where to take them to have them fixed,well now that you can get the proper tool kits for phones from here and can buy the charger port off of ebay or Amazon for any where between $6-$30 you can save your self a big charge taking it to your provider and do the same Job yourself and in the process learn more about your phone and how to fix the issue again or on a friend's phone. YouTube has all the DIY videos on most to all phones,so fixing this issue is way less stressful.
このアンサーは役に立ちましたか?
Try a restart. My Galaxy went from 15 to 96%, just like that. Not a great portend for this new phone. "/
You do is the connector are broken or blew a fews now I know the connector are the problem
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 1
過去 30 日: 5
今までの合計 611
5 件のコメント
We need a bit more info. What does the phone do? Does it turn on, vibrate, or make any sounds?
guardian10 さんによる
I have a question my Samsung A02s is not charging anymore what the problem with it
Edin Cerritos さんによる
I have a similar problem but it has to be in a Cretan direchen
Phillip Norton さんによる
@Phillip Norton what model is your phone. It sounds like a bad charging port. Let us know the model and I am sure we can guide you to a good repair
oldturkey03 さんによる
Yes, my mobile is not charging, the issue of temperature is coming, it will be four days
Ahmar Abbasi さんによる
