メインコンテンツにスキップ
DUALSHOCKシリーズの後継機種である初代Sony PlayStation 5 DualSenseコントローラーの修理ガイド、分解、トラブルシューティング情報。 型番はCFI-ZCT1W、マザーボードの型番はBDM-010です。
20回答 すべてを表示
The ps button on my ps5 controller not responding?
I've opened up my controller and checked to see what it could be. But i do not see any reason why the button is not responding when i put it back together. I have cleaned the the casing the pad and everything the ps button touches but no response
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 3
19 件のコメント
Same, And I doubt someone has the answers, If you’ve fixed it by now I would appreciate if you’d reply
さんによる
I haven't fixed it yet, i still cannot identify the problem. I thought this chat room would help as it is very informative with issues on gaming equipment. Hopefully someone can give me some insight
さんによる
When you plug it in, does the light bar slowly light up orange then quickly flash off one time? If so then it’s the same issue as mine. Can’t seem to find any insight or answers for this. I even tried swapping battery from a known working dualsense; didn’t work.
I bought the Dualsense controller for use with my iPhone, until I can afford a ps5 console. There is even less information and answers out there for people with an issue but no console… please update if you have found anything.
さんによる
@sirswolls Having the same problem as you do after a shell swap, any answers yet or fixes?
さんによる
@gamechan you might need to open it back up.
have you checked that all connectors are fully on?
are any cables torn?
did you damage any components?
could any of the componets have been affected by ESD (electric static discharge)? (you can check by seeing if your workspace is has a sticker or anything like that that claims to be esd safe, or if the table you worked on was completely wood, lol)
さんによる
14件以上のコメントを表示
コメントを追加
1 件の回答
最も参考になった回答
Here’s some pictures, unfortunately I can’t add any videos longer then 30 seconds so this is the best I can show for now. But I managed to fix the orange light problem by replacing the battery of the controller.
このアンサーは役に立ちましたか?
スコア 2
4 件のコメント:
i can't see them, maybe this is a me problem tho, lol
nvm i can't see them on anything
さんによる
@timtomissus I'll try something else hold on
さんによる
@gamechan, here's how to add pictures to your answer.
iFixitでの質問に画像を追加する方法
さんによる
@dadibrokeit thank you <3
さんによる
コメントを追加
回答を追加する
Munir Umar さん、ありがとうございました!
統計データ:
過去 24時間: 3
過去 7 日: 16
過去 30 日: 46
今までの合計 1,297
