How to charging point
how to fix charging pin
この質問は役に立ちましたか?
お持ちのデバイス用の修理ガイドとパーツ一覧とアンサーフォーラムにアクセスする。
Just buy a new charge port, comes as a complete board. Just open the phone and swap it over. No soldering involved.
このアンサーは役に立ちましたか?
Hi
Unfortunately you can’t really fix a connectors pins without replacing the whole connector as they are very small and it could be too far gone
You will have to solder on a new one to fix the issue or replace the board/cable if it’s attached to one
If you post a picture of the inside using this amazing guide I can confirm that for you as it could just need cleaned rather than replaced:-)
If you need any help let me know
Hopefully this helps
Any questions please ask
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 3
今までの合計 346
