メインコンテンツにスキップ
識別情報を用いた1−2文節からなる文章で説明してください。 例: 2009年6月発売。モデル番号はA1303。
13回答 すべてを表示
Why does my power button blink 3 times?
i recently found my lost laptop. When i plug in my charger the power button flashes 3 times and then nothing happens from there.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 8
1件のコメント
I have the same Issue with my Lenovo X1 carbon 6th. When I press the power button nothing happens. But when I plug in the AC cable the light on the back flash tree times. And there is some sound from the processor.
さんによる
コメントを追加
2件の回答
ベストアンサー
For others reading this there are two power staus lights.
One is for the AC power located on the back of the computer.
The other one on the top right from the keyboard is the power on light.
Rick have you tried activating the emergency reset button.
This is located on the bottom of the laptop and can be activated by inserting a paperclip in the hole.
Here are the steps:
  1. Unplug power
  2. Find a thin paper clip
  3. Locate the Emergency Reset Hole on your laptop
  4. Press and hold the Reset Hole for ten seconds with the paper clip
  5. Power on
このアンサーは役に立ちましたか?
スコア 13
9 件のコメント:
Hello Mike,
I have the same problem with the same laptop brand.
Lenovo Thinkpad T480. I tried the reset method but nothing changed,
Maybe there is something more i can do to check for the problem.
I will apriciate if u have any other advice.
さんによる
Hi @andreaq,
Some how missed your question.
Here is link to service manual:
https://download.lenovo.com/pccbbs/mobil...
(from page 44) Blinks three times:
• Three Blinks quickly: The computer is entering sleep or hibernation mode.
• Three Blinks slowly: The computer is in sleep mode.
Page 35 explains sleep and hibernation modes.
さんによる
couldn't find the reset button. i just reseat the battery and it was successfully powered on.
さんによる
Yes I found the reset hole in the back of laptop. I inserted the push pin, reset it and it worked for me. Thank you Rick for the post.
さんによる
Thanks a lot, it saved my day as well.
さんによる
4件以上のコメントを表示
コメントを追加
Remove/disconnect both batteries. Remove RAM. Disconnect "button battery".
Wait more than 1min.
Reconnect all.
It worked for me.
このアンサーは役に立ちましたか?
スコア 0
2 件のコメント:
Same symptoms, but pushing (with paperclip) and holding the reset button on the bottom of my Lenovo T16 fixed mine.
さんによる
Emergency reset on bottom of the laptop will only work for about 3 times. So make backups and check for warranty. The second time this happens bring in for repair and demand them to fully boot regularly for about 4 or 5 times after reset.
さんによる
コメントを追加
回答を追加する
Rick smith さん、ありがとうございました!
統計データ:
過去 24時間: 93
過去 7 日: 1,009
過去 30 日: 4,668
今までの合計 158,127
