メインコンテンツにスキップ
The LG V60 ThinQ 5G, commonly referred to as the LG V60, is an Android phablet manufactured by LG Electronics as part of the LG V series. It was announced in February 2020 and is the successor to the LG V50 ThinQ. On April 5, 2021 LG announced it will be shutting down its mobile phone division and ceasing production of all remaining devices. LG noted the phone will be available until existing inventory runs out.
20回答 すべてを表示
Replace LG V60 swollen battery
Is it possible that I can replace the battery myself in an LG V60 ThinQ 5G?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 4
1件のコメント
Chargeng problem
さんによる
コメントを追加
1 件の回答
最も参考になった回答
RAYMOND A BYRNES JR yes you can. Just follow something like this video A bit of patience and the right tools will make all the difference.
このアンサーは役に立ちましたか?
スコア 1
3 件のコメント:
this video is way to involved to just replace a battery
さんによる
@rayharmacinski You may be right on this one. I'm not sure I see why the motherboard and charging board needed to be removed on this video. I found a similar guide for the V40 ThinQ that just shows the antenna plate coming off then the battery being removed. You'll have to use your best judgement as to whether this same technique will work the same for your V60 though.
https://www.nadiemellamagallina.com/en/m...
If you do end up figuring it out, you can always help others who come along with the same problem by creating your own guide to this repair.
https://www.ifixit.com/Guide/new
さんによる
@rayharmacinski you are absolutely right. That video is for a complete teardown. You only go as far as you need to, in order to remove the battery.
さんによる
コメントを追加
回答を追加する
RAYMOND A BYRNES JR さん、ありがとうございました!
統計データ:
過去 24時間: 3
過去 7 日: 34
過去 30 日: 99
今までの合計 4,130
