メインコンテンツにスキップ
2012年半ばモデル、A1278/2.5 GHz i5または2.9 GHz i7プロセッサー。
Stripped srew on back of MacBookpfro
I need to replace the fan in my Macbookpro. The problem is that there is a stripped screw on the back of the Macbook. How do I remedy the problem without taking it to the genius bar?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
ベストアンサー
You need a jeweller's screw extractor. Look for for a jeweller's tool supply firm. You will need to look around a bit for it as they are much smaller than the ones you normally find at machine shops.
You will want the type that requires drilling a pilot hole first. They are conical in shape with steep spiral cutting edges that cut into the screw in the pilot hole turning counter clock-wise to unscrew it. Read up on the technique as much as you can before actually doing anything, to avoid a disaster.
The most common cause of stripped screw heads is insufficient pressure on the screw driver that then allows it to slip on the screw head.
Good luck.
このアンサーは役に立ちましたか?
スコア 2
1件のコメント:
Thank you for the advice. I will search for the part.
さんによる
コメントを追加
回答を追加する
ladycerridwyn さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 53
