メインコンテンツにスキップ
Dell XPS 2in1ノートパソコン。2018年初頭発売、型番9575。
6回答 すべてを表示
Usbc ports not working, hardware issue
The usbc ports have one by one stopped working, with the last only functioning at half capacity. Damage appears to be physical- what options are available for repair/replacement? If
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
3 件のコメント
Is their any visible damage to the ports, or the actual charger itself?
さんによる
To the charger no, but when I had a tech friend look at it they recognize the physical damage, which could only be from general use
さんによる
And no dirt or debris of any kind?
さんによる
コメントを追加
1 件の回答
最も参考になった回答
Well, i’m sorry to be the one to tell you this. But unfortunately there’s not an easy way to fix the ports on this device that doesn’t require micro-soldering skills. Thankfully, there are some reputable micro-solderers that troll the forums every once in a while and you can find some of them here.
このアンサーは役に立ちましたか?
スコア 1
2 件のコメント:
Excuse my ignorance, but the soldering is needed to repair them or to swap for a replacement board? It would be enough for me to have them working again on at least one side, but the current issue seems to be finding any place or person that can do the job. I’ll have a look at that link thank you
さんによる
@Jennifer Leo the soldering if for the repair of the ports. The board itself should be fine, it's just the ports.
さんによる
コメントを追加
回答を追加する
Jennifer Leo さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 3
今までの合計 407
