メインコンテンツにスキップ
長く待ちわびた人気モデルMac miniの最新モデルです。プロセッサはオプションで3.6 GHz quad-core Intel Core i3、3.0 GHz 6-core Intel Core i5もしくは3.2GHz 6-core Intel Core i7プロセッサから選べます。
20回答 すべてを表示
I installed ram today, no power.
Mac Mini 2018 - I installed ram today, no power...double checked everything, no power. Install was smooth, no hiccups, no missed steps signs of stress nor damage. Thinking issue had to be the ram, put the old ram in and the mini now only gives a quick spurt of the fan, then off...rinse and repeat. Can’t image what I did or any damage caused. Anyone else experiencing this? Thoughts?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
1件のコメント:
Update - as many times I checked ram was not properly seated. Everything running smooth now!
さんによる
コメントを追加
1 件の回答
Good morning (From Australia),
Did anything on the motherboard short out and thereby cause something to earth and die?
Did you check all your connections?
Is there anything on the display out
このアンサーは役に立ちましたか?
スコア 0
2 件のコメント:
Good morning!
Process does not run long enough for the display to show signs of life. Fan kicks on high gear for about 5-10 seconds, sits quiet for about 20 seconds. Think the connections are as expected. Took everything apart and back together many times looking for an issue with a connection….and the original and new ram looking for any signs of change.
Short out? Nothing that was obvious and can not see any issues..
さんによる
Good morning!
さんによる
コメントを追加
回答を追加する
Pixel さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 5
過去 30 日: 10
今までの合計 84
