メインコンテンツにスキップ
The Samsung Galaxy A40 was released in April 2019.
28回答 すべてを表示
Why my sim card not working as data network
i have a tray for dual sim cards but there is one of sim card not working in my phone for data network but its working in other phones even i put another sim in my phone in same tray and it is work very fine then i went to the branch to replace the sim card but it also do the same issue no data network in my phone but working very well in another phones so why the data network in this sim card exactly not working
notes
I call customer service technical support to resolve the problem but no problem in sim card because i try it in another phone
also my phone is fine because i try another sim card and it works
so how can it fix
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
最も参考になった回答
Hi,
Check that the phone's data saver setting is either disabled or that selected apps only can use the data and also that the required SIM card(s) are selected for the data connection.
Here's an image from the user manual that may help.
(click on image to enlarge)
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
If your phone and SIM cards work, but the data connection doesn't, I can think of a few reasons:
  1. The SIM cards are in the wrong trays. Try switching the cards in the trays and see if it works.
  2. The dual-SIM setup is configured incorrectly. A branch technician needs to confirm everything works before giving the phone back to you.
  3. The dual-SIM setup is not part of your current phone plan. Customer support needs to explain the features you purchased.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Amr Doh さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 19
過去 30 日: 79
今までの合計 3,189
