Is the RAM upgradeable?
I wanted to upgrade the RAM, but I can’t find it in the laptop. Is it on the MB?
この質問は役に立ちましたか?
お持ちのデバイス用の修理ガイドとパーツ一覧とアンサーフォーラムにアクセスする。
この質問は役に立ちましたか?
HPs documentation indicates that the RAM on this model is soldered onto the board. So for all intents and purposes, no it is not user upgradeable.
このアンサーは役に立ちましたか?
What if the RAM fail? My computer RAM Failed but not removable
@Biruk Ayele You might be able to find a repair technician who does board level repairs that can diagnose the issue and replace either the RAM chips themselves, or whatever faulty component is causing the problem.
Otherwise you'll have to replace the system board to restore functionality.
This seems to be factory configured
“About your EliteBook x360 1030 G2
Your computer's memory capability:
Standard memory:
4GB to 16GB non-removable”
このアンサーは役に立ちましたか?
"The HP EliteBook x360 1030 G2 comes with 8GB DDR4 RAM on board, and there is no spare RAM slot, so you can not upgrade the RAM."
HP EliteBook x360 1030 G2 Disassembly (SSD, RAM Upgrade Options)
A pretty detailed tear down https://www.laptopmain.com/hp-elitebook-...
過去 24時間: 5
過去 7 日: 23
過去 30 日: 118
今までの合計 9,858
