Why does the planetary unit fall out?
The planetary unit falls out of my mixer. Nothing seems to be securing it. I can push it back in but it won’t stay.
お持ちのデバイス用の修理ガイドとパーツ一覧とアンサーフォーラムにアクセスする。
I, too, have a pre-2005 KitchenAid 600 Series Professional mixer and the same thing happened to me yesterday. There is nothing inside the mixer that seems to hold the planetary in. The top of the planetary has a lot of little grooves that appear to possibly hold the head in by friction. After spending some time finding a place for it to easily slip in (testing fit as I slowly turned it) I found a place where it slipped in easily. Before I rocked it in, I applied food-safe grease to all the gears. I then pushed it in and gave it a few taps with a rubber mallet to make sure it was seated. It seems to be working fine, but I will update if something else happens.
このアンサーは役に立ちましたか?
I have the same problem. No set screw appears to be available. There is a spline on the bottom of the vertical shaft that connects to a corresponding spline on the planetary gear portion of the mixer. Nothing appears to hold this splines together, except friction. Any other ideas?
このアンサーは役に立ちましたか?
Mine is still holding together when I assembled it as described above.
Thanks Flipperroni. That is good to hear that your fix is lasting. I held a piece of wood on the top of the vertical shaft (after removing the gear grease cover) and hammered with a plastic mallet up from the middle of the planetary gear/beater attach area, to seat the splines together with some force. I hope that this holds as yours is.
There is what is called a set screw that holds the cap in place. this has probably backed out enough,. usually this is a HEX key and you just need to retighten it.
このアンサーは役に立ちましたか?
No set screw is visible. Where could I find it? The planetary unit appears to be a friction fit.
Maybe newer units have the set screw. Mine is 10 years old. Thanks
@bjmg do u have a picture?
Did you ever get a response. We have one that's 6-7 years old. Pro 620 limited edition.
There is no set screw on a Professional 600 mixer.
@bjmg check to see if your unit still has the retaining clip and/or the pin to keep the planetary gears in place. Check the attached manual and see if that is consistent with your unit. Also, see if you have a proper model number on your unit so we can try to identify anything that might be specific to your mixers gears.. KitchenAid Planetary Gear Repair
このアンサーは役に立ちましたか?
Thanks for supplying the manual. I forgot to my bad. And yeah that's the pin or screw i was taking about.
Also sometimes I've seen them just a friction fit. Did you try a rubber mallet and tap it down?
If neither are helpful you can use CA glue or tightbond red or purple to seal cap on
過去 24時間: 4
過去 7 日: 14
過去 30 日: 65
今までの合計 5,066
