メインコンテンツにスキップ
2017年3月に発売されたiPadの第5世代のLTE対応モデル。9.7インチRetinaディスプレイと64ビットA9プロセッサーを搭載しており、32 GBおよび128 GBのストレージオプションがあります。
20回答 すべてを表示
Home button not working
Hi,
I purchased an iPad described as “badly cracked screen but everything else working perfectly”
When I received it I discovered the home button wasn’t working. I wasn’t too worried as I noted a hole in screen above home button ribbon cable, and I could just order a screen with a button.
After changing screen I have found it is still not working!
Q1. Could I test it with a home button from an iPad 7? Or would that cause damage/not work anyway? (I ask because I have one that I could try)
Q2. If it's not the home button, how hard/easy would it likely by to have problem diagnosed and fixed? The connector looks fine to my eye.
Any advise on course of action would be appreciated
Thanks
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
1 件の回答
ベストアンサー
You might have ordered a digitizer with a home button for an iPad Air pre-installed. These are common because the Air does not have touch ID. You have to order a home button specifically for an iPad 5.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Thanks for that, I think you are right.
I ordered an"iPad 5 digitiser with home button flex" but pretty sure button is for Air.
Annoying, but a relief!
さんによる
コメントを追加
回答を追加する
Chris Reader さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 1
今までの合計 72
