How can fix Black spots in the screen
Update (09/10/2021)
black spot
お持ちのデバイス用の修理ガイドとパーツ一覧とアンサーフォーラムにアクセスする。
Hi,
The LCD panel is faulty and needs to be replaced as it cannot be repaired.
Here’s the hardware maintenance manual for the laptop.
Go to the bottom of p.106 to view the necessary pre-requisite steps and then the procedure to remove/replace the LCD panel.
Replacement panels are available online. Just search for Lenovo T530 LCD screen to find suppliers that suit you best.
Usually the Lenovo part number can be found on the back of the panel itself, if you wish to confirm that you’re ordering the correct one, as there are several different panels available for the model series. If there is one there, then search for the LCD panel part number instead of the laptop model number, to be sure that you’re getting the correct one. Alternatively contact the seller and verify that it is compatible with your exact model.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 4
過去 30 日: 13
今までの合計 372
2 件のコメント
what did you do to it before it got black spots
john さんによる
Hi @adly83 ,
Post an image of the problem so it can be seen.
Here's how to do this on Ifixit iFixitでの質問に画像を追加する方法.
Have you tried connecting the laptop to an external monitor and check if the problem is on it or if it is OK?
jayeff さんによる
