メインコンテンツにスキップ
MacBook Pro 16インチの解体情報と修理ガイドです。2019年11月に発売されました。モデル番号はA2141とEMC3347です。
20回答 すべてを表示
My MacBook Pro completely died
My 2019 16" Macbook will not start up...
I bought the Macbook Pro June 2020.
Why would a new Macbook Pro not start?
Apple help can't figure it out either.
Can someone help me figure this out!
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 3
2 件のコメント
Can you provide any information on when the last time was that the macbook was working? Also, is it completely dead (i.e. no lights no fan no sound)? And is there any light appearing on the AC charger?
さんによる
Did you find any solution? Mine died the same way. Just decided not to turn on one morning and none of the usual solutions work. Just over one year after purchase. :-(
さんによる
コメントを追加
2件の回答
最も参考になった回答
Just called apple and they gave me keys to test out.
Try this.
Using left hand hold Control & Option
Using right hand hold Shift in unison.
Hold for 7 seconds
While continuing to hold those down
Hold the power button down for another 7 seconds
And release after.
You should see start up screen after a few seconds.
Hope this helps someone!
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
Appreciate the post. Power button alone was not working. Using your tip, was able to get control back. Ended up reinstalling the system.
さんによる
コメントを追加
I would return it to Apple, then maybe you could downgrade to the MacBook Pro early 2008. Those are much better computers, and can run the latest Mac OS with a patcher.
Hope that helps,
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Arpitha Sylvester さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 4
過去 30 日: 18
今までの合計 825
