メインコンテンツにスキップ
Battery compatible with Mate 10 Lite?
Does anyone know if the battery ifixit sells for the mate 10 is also compatible with the mate 10 lite?
https://store.ifixit.de/products/huawei-...
There’s no battery explicitly for the lite version. It’s so %#*@ hard to find the actual battery specifications of the phone, I just found the capacity which is higher in the above battery.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
1 件の回答
ベストアンサー
Hi @kryptojude ,
They are different batteries.
The model number shown for the Ifixit battery that you linked is HB436486ECW (printed on battery)
The model number of the battery in a Huawei Mate 10 Lite as seen in this video is HB356687ECW - see image taken from video.
They have different dimensions and capacities and I don’t know if they have the same pin out connections in the battery cable.
Mate 10 battery dimensions = 4.3mm x 64mm x 86mm, rated capacity 3900mA
Mate 10 Lite battery dimensions = 3.5mm x 66mm x 87mm, rated capacity 3240mA (actual capacity 3340mA)
Here are the full specifications for the phone
(click on image to enlarge for better viewing)
このアンサーは役に立ちましたか?
スコア 3
1件のコメント:
Thanks a lot!
さんによる
コメントを追加
回答を追加する
Kryptojude さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 5
今までの合計 404
