メインコンテンツにスキップ
Model A1418 / Late 2013 / 2.7 & 2.9 GHz Core i5 or 3.1 GHz Core i7 プロセッサ
Fan acting crasy af SSD upgrade
Hello out there,
I’ve recently upgraded my iMac Intel 21.5” Late 2013 with a Samsung EVO 860 500GB SSD instead of the original HDD.
I’ve followed the instructions on ifixit and multiple YouTube-videos and didn’t have any problems in the process.
Afterwards i’ve got a lot of problems with the fan acting crazy even when I only perform simple tasks.
It happens especially after the iMac has been shot down or waken from sleep. Sometimes the fan is at full blast of over 4000 rpm, and other times it switch between 0 rpm for a couple of seconds and 4000 rpm for a couple of seconds and so on.
Have I done something wrong? Should i’ve installed a Thermal Sensor on the drive? Many places people stated that it could fix the problem, but as far as I can see, it’s only necessary on iMac 27” or older 21.5”.
I’ve tried to use different fan control programs like Macs Fan Control or SSD Fan Control, but it seems like they can’t control the fan at all..
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
ベストアンサー
I believe the thermal sensor is required on most iMac’s, 27” or 21.5” models. Since the fan is acting weird, I’d say its a good bet. I have done SSD upgrades in the past and have realized it’s a crap shoot, some iMac’s require it, while others don’t; honestly I wasn’t able to find a definitive answer especially in the 2012-2013 model years.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Johan さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 54
