メインコンテンツにスキップ
The Sony Xperia XA2 is an Android smartphone manufactured by Sony Mobile and succeeds the Xperia XA1. Released in 2018.
3回答 すべてを表示
H3133 replacement motherboard. Are they interchangeable
I'm trying to track down a h3133 motherboard. I'm seeing alot of motherboards for the phone, however they're not h3133, will they fit and work as a replacement part?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
I replaced the motherboard on my note 9 and the numbers didn't match but it worked make sure they are the same shape and that it has the right connectors before you buy if you are unsure ask the seller if it can replace your board they'll tell you if it's good for your device or
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Andrew Douglas さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 3
過去 30 日: 3
今までの合計 225
