Where do I find parts
where can i find the parts,fuses,powerboards?my tv worked just fine it just went off one day and wont come back on,had no warning of anything being wrong,
この質問は役に立ちましたか?
お持ちのデバイス用の修理ガイドとパーツ一覧とアンサーフォーラムにアクセスする。
この質問は役に立ちましたか?
Disconnect power supply and take rear cover off. The boards.. Usually 3, will have part numbers on them. Take a look for any bulging or leaking capacitors (brownish gunge running downwards) you can try desoldering and replacing those caps or buy the entire board they are on. Cap replacement is the cheapest option. buying a board from eBay or similar can be done easily.. I bought 3 boards for 1 tv and none worked! They tend to be taken from other broken tvs! Just check feedback and returns policy first. I'd never fixed a tv before and found it fairly straight forward. Just take your time, use a camera to take photos along the way so you know how to reassemble.btw... Is this sound no picture, no power at all? You might like to check plug fuse or that wall outlet is ok too.
このアンサーは役に立ちましたか?
Ps have you tried the guide linked on the right under the photo?
and do feel free to download the service manual from here :-) Good Luck
Depending on where you live, try one of these areas on PartsIn.com:
It mainly aggregates classified ads, so you never know. You might get lucky and score exactly what you need for real cheap. You usually have the option to haggle with them because often the sellers don't find a buyer and they just end up throwing it out anyways.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 1,275
