メインコンテンツにスキップ
The Bose SoundLink Color is a Bluetooth speaker, designed as a more affordable and portable alternative to the SoundLink Mini.
44回答 すべてを表示
How to unscrew these stripped Torx TR screws?
These are the stripped Torx TR screws (not my job):
I am waiting for Torx TR tips to arrive, I will try with a rubber band first. Any tips to unscrew them without destroying the case?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
最も参考になった回答
Doing what I’m about to say you may need to get new screws once done. I’ve had an issue at work with striped Penelope screws on iPhones ( because people use wrong/crap screw drivers) and with no other way, I took a “one time” use Penelope screw driver so if need be could throw it away and put some adhesive bonder or maybe could use superglue and dap a tiny amount on screwdriver, let sit in place on stripped screw once harden you should be able to unscrew it out. Since I used a type of adhesive bonder there is a DeBonder to get the screw driver and screw apart. Sorry for the long reply. Hope works out for you mate.
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
The screws are 5-points Torx Security, size 15; however the shaft of my multibit seems too fat to fit in the plastic canal.
Which multibit (precision?) screwdriver should I get? The canal seems to be just 8mm wide and that's going to be a challenge with these short Torx security tips (I can't find the long version, I think they don't make it).
さんによる
コメントを追加
The unique Torx design means that there is less likelihood that the screw head will be stripped or the screwdriver damaged. Torx screwdrivers can last up to ten times longer than regular screwdrivers especially they are stripped.
In your case, you may need a T5 Torx Screwdriver.
T5 Torx Screwdriver
Kindly check out methods for unscrewing a stripped one.
https://www.youtube.com/watch?v=_mTFQbaT...
Please do keep me updated, good luck!
T5 Torx Screwdriverの画像
製品
T5 Torx Screwdriver
$5.49
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Yklamin さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 10
過去 30 日: 48
今までの合計 870
