メインコンテンツにスキップ
A business class notebook manufactured by HP in 2014. Model number: M0X64US#ABA
Laptop not switching on with battery sometimes
My laptop switch on when connected to power. If you don't use it for about 5 days, it can switch on on battery. When it's in power, it does not charge the battery more than 76%.
So sometime it works on battery and sometimes it doesn't. What could be the problem
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
Do you know if the battery is original? This was released 6 years ago and most PC batteries last 2-3/4 years.
If you can get it to start without the battery, one of the cells is bad. Refer to this guide to disconnect it and see - that should be sufficient for troubleshooting unless it has to come out due to it’s design.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Thank you for your quick response.
I bought this pc from ebay UK.
I ordered a brand new battery after this problem started. But the problem is still there
さんによる
コメントを追加
回答を追加する
Kumbirayi Chitauro さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 14
今までの合計 220
