メインコンテンツにスキップ
2017年3月に発売されたiPadの第5世代のLTE対応モデル。9.7インチRetinaディスプレイと64ビットA9プロセッサーを搭載しており、32 GBおよび128 GBのストレージオプションがあります。
iPad 5 Not Charging
I had a customer bring me an iPad 5 that doesn’t charge. I managed to get it to charge at 1amp sometimes but most times it charges at 0amps…
I checked vchargr and it was showing 4.2volts.. I changed Tristar and now the line shows 5 volt and I also changed charge flex and that didn’t do anything either…. So I tested vbatt on battery connector while plugged in and it shows 1.4 volts instead of 3.7 volts. I looked at a schematic board view for an iPad Air and they are totally different…
I plugged cable in without battery and the amperage goes to about 0.12 amps 0.15amps 0 then moves around but when I plugged battery back in and it boots, it goes back to 0 amps…
Did I install Tristar wrong or is something on vbatt line bringing the voltage down.. When the iPad boots, an I have cable plugged in, it says unlock device to use accessory then starts charging at 0.5amps which should be 2 amps…
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
This is me the author from above.
i am just letting everyone know that I replaced tristar again with a new one and the iPad charges again!
just thought I’d let everyone know in case someone has the same issue as me. Make sure tristar is working !
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Daniel さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 5
過去 30 日: 8
今までの合計 225
