メインコンテンツにスキップ
An affordable mid range laptop sold by Acer in mid 2015. This laptop comes with a Nvidia 940m graphics card, Intel i5-5200U CPU, and a 1080p display.
20回答 すべてを表示
Why does my laptop shut down when I unplug it?
I have an Acer Aspire E5-573G (i3-4005U, 8GB RAM, 920M). About 6 months ago a problem started occuring. Whenever I unplug the power cable, the laptop just instantly shuts down. My first guess was to replace the battery, but that did not do anything. What could be causing the issue here? Originally it was stuck at 31% battery and slowly degraded over time, and no matter how long i plugged it in for, it wouldn’t charge.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
if you have a spare laptop same model which has a battery backup power try using that and check,
or drain the battery completely and keep it for a full charge for 4 or 8 hours and check
If not you will have to replace the battery. better
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
I already replaced the battery, but it did not work.
さんによる
コメントを追加
回答を追加する
Some Dude さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 132
