メインコンテンツにスキップ
Repair guides and support for 17" laptops in the Pavilion Notebook 17 series. These laptops have model numbers 17-g000 – 17-g099.
16回答 すべてを表示
Laptop doesn’t boot makes clicking sound and then repeats
Laptop makes a click or spark sound around the CMOS battery area
17 inch HP Pavilion with i5 4th gen processor
Recently replaced my HDD to an SSD and when I went to test out the SSD I accidentally picked up the laptop to turn it around and forgot about the rechargeable battery which immediately turned off the computer.
I tried rebooting the computer again and it just turns on all lights with fan running and then few seconds later turns off and hearing a click sound that happens when you hard power it off (holding down the power button) and then repeats
What I tried already was resetting the power multiple times and also connecting with only AC adapter to no avail.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
4 件のコメント
James Chen exactly what happened when you "forgot about the rechargeable battery" and turned your laptop over?
さんによる
@oldturkey03 what I mean by that was when I picked up the laptop to turn it around the rechargeable battery came out of its battery contact pins and the computer completely turned off
さんによる
Yes, that is what I thought. Have you checked the connectors/cables and traces to make sure that nothing came loose or got pulled off?
さんによる
Yes I have took each and every cable out and re connected them.
さんによる
コメントを追加
1 件の回答
最も参考になった回答
well this happened to my old computer and was told that i fried the board while trying to replace my hdd
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
James Chen さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 559
