メインコンテンツにスキップ
The Chevrolet Silverado is a line of trucks under the Chevrolet brand and manufactured by General Motors. Mechanically, the GMC Sierra and Chevrolet Silverado are identical.
21回答 すべてを表示
Column Shift lever moves freely but does not engage gears
As I was parking my truck earlier I pulled up and quickly put it into park and turn off the key. What I noticed was while turning it off, the vehicle never made it to Park. The shift indicator is located in reverse however I cannot engage the shifter into any gears to move it into Park. At this time, I cannot start the vehicle as it will not enter neutral or Park. I've seen videos on older models needing a solenoid replacement got.. Anyone know if that's the case here?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
From my experience with this issue I would say that the shifting linkage has become disconnected at the transmission.
The best thing to do is have it checked by a certified GM Mechanic.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
If you want to fix it yourself then buy the top and bottom part of the shift cable and I will be !&&* but if can replace it. I'm sitting in the parking lot right now doing this and got curious. Try to replace the whole cable and it will be fixed because if you buy another bushing then it will pop off 1month later and will soon do it every day.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
How hard was the replacing of the cable? Can it be done without jacking up the car?
さんによる
コメントを追加
回答を追加する
bgtackle さん、ありがとうございました!
統計データ:
過去 24時間: 16
過去 7 日: 159
過去 30 日: 823
今までの合計 16,066
