メインコンテンツにスキップ
Released July 12, 2002. Identified by model number K45SSWH.
20回答 すべてを表示
Will not start on low speeds
My 32 year old KitchenAid Mixer Model K45SS (no WH at the end) will not start until I move the speed lever to at least 5 (that gets messy!). I can then move the lever back to the lower speeds and it will work fine.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
1件のコメント:
User Manual which contains information on toll free phone number for USA only (probably only for information on nearest service center and after 32 years more than likely out of date)
https://www.manualslib.com/download/1078...
That and done, your unit needs servicing. If doing the repairs yourself, open up the unit and do a visual inspection of the speed switch along with continuity and voltage testing using a multimeter. More than likely it will need replacing.
さんによる
コメントを追加
2件の回答
Replace the Speed Control. Here’s the part:
KitchenAid Speed Control WPW10119326
This part fits model K45SS
https://www.kitchenaidparts.com/PartDeta...
Here’s a video on how to do it.
https://www.youtube.com/watch?v=HMRqoz3y...
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
My KitchenAid Model No K45SSWH stoped will It was working, when I open the back play I found a loose pice that look as a square U with a ceramic cylinder. I imagine that I have to replace the control plate and find if I need that pice? Please let me know what part to buy
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
please correct: should say Stoped while and the back plate instad of play
さんによる
コメントを追加
回答を追加する
Mary Boudette さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 5
過去 30 日: 15
今までの合計 6,422
