メインコンテンツにスキップ
2014年10月16に発表されました。モデル番号はA1347でEMC番号は2840です。
Why Mojave and ARD don't work?
I know this topic has come up before. I know there are other alternatives out there which might be better and may work.
I have a Mac Mini 2014 running Mojave at home and I want to have remote access to it. I do have Remote Management enabled and Remote Login enabled. Also, my name is allowed access. I am signed in to iCloud and related services.
When I am sitting at my work computer (iMac), I want to have remote access to my home computer. I know that BTMM and related components have been removed from Mojave which makes doesn't help the situation.
I have ARD on my work computer and my home computer (Mojave computer) doesn't appear in ARD. I am not sure if I have to Port Forward anything on the router to get this computer to appear in ARD. Again, I know about Screens, Chrome Desktop Remote, Teamviewer, etc.... but I would like to try and get this to work, if possible.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
The first thing I would do is setup ARD on a second system at home to make sure it works on a flat network. If you can run WireShark aka Ethereal on a third system you should be able to watch the connection between the two systems (make sure you aren’t using a layer 2 switch as that will filter the data flows on the network monitoring station).
With the WireShark data in hand you should be able to adjust your home router the needed port access.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
jkbmjp さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 58
