メインコンテンツにスキップ
Microsoft Corporationによって製造されたXboxワイヤレスコントローラー7MN-0001は、PCでも使用できるXboxゲームコンソールに最もよく使用されるコントローラーです。
Why is my right thumbstick drifting out of position?
I’ve seen many questions about how to fix a joystick that is stuck in position, but that doesn’t apply to my controller. What happens is if I’m playing Call of Duty (or any game for that matter) I start to look upwards even when I am not making contact with the joystick. At first I thought that maybe it was getting stuck while pushed forwards, but then it started to happen for no reason. Then I decided to test something, I tested how far forward I would have to push the joystick to make me look up at that speed, then I waited for the joystick to malfunction, then I saw that my joystick was in the proper centred position: nowhere near how far forward it would have had to be if this was an issue of it being stuck/sticky. Does anyone know if I can fix this, or is this just a sign that it is time for a new controller?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
ベストアンサー
That’s how these cheap things are expected to do when worn, the measurement drifts.
Replace the joystick mechanism.
このアンサーは役に立ちましたか?
スコア 2
1件のコメント:
Is it less expensive to replace the joystick mechanism, or just get a new controller? I also have had the controller for almost 6 years, and I have used it extensively, so there was bound to be some problem with it eventually.
さんによる
コメントを追加
回答を追加する
Alex さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 184
