メインコンテンツにスキップ
The Dell Chromebook 11 3180 is a cost-effective, student laptop that runs on the Chrome operating system. It was first released on Feb. 7th, 2017.
11回答 すべてを表示
Why is my dell chromebook 5190 2 in 1 not charging?
I’ve plugged my chromebook and the white light on the corner led light is on only while it’s plugged in but it is just a black screen and it’s been charging for 7 hours and won’t turn on and i’ve tried everything. holding power button, holding the power and reset button, turning up the brightness, etc.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
3件の回答
May be a faulty battery that isnt accepting the charger port, or it may be a damaged motherboard or the battery is burnt out completely. Try replacing the battery first.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
You’ve probably figured this out already, but here’s for the late-viewers. The Chromebook power shorted out on it. What you need to do is unplug the battery, and plug it back in. And then plug in the power cord, and it should start charging. We have this issue at my High School, I help fix every Chromebook that comes in.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Well if you bended your charger to plug in your computer and if you kept on doing that it would break the inside of your computer so you couldnt charge it.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Genah L さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 22
今までの合計 1,369
