メインコンテンツにスキップ
PC laptop by Dell with a 15.4" display. Succeeded the Inspiron 1520.
20回答 すべてを表示
tried to reboot on safe mode.Started loading windows now frozen.
at start up,screen shows loading bar continualy. Windows does not start. I tried to boot on safe mode but "windows files started loading" immediately; now its frozen with the message ,Please wait... and every now and then I hear a click sound, not clicking multiple times just one click, and again like 3 or 4 min. apart. Does any one have any clue, I realy don't know what to do.
ablessedmom
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア -1
コメントを追加
3件の回答
ベストアンサー
See if you can boot from your system disk (if you made one).If not see if you can borrow one to try booting your computer. If you can rather than install select repair system. If this does not work you may have a bad hard drive. Another possibility could be your cmos battery. I am including a link about that for you to look at.
http://forum.notebookreview.com/dell-ins...
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
or faulty ram
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Hi,
You have to Re install the windows in your laptop because if it is freezing during load then that means some of the files are either missing or has corrupted. Insert the bootable install CD in your laptop and install a fresh windows for your laptop.
Good Luck.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Sylvia さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 2,658
