メインコンテンツにスキップ
The Xiaomi Mi A2 (Also known globally as the Mi 6X) was released by Xiaomi in July 2018 in various internal memory configurations. It is part of the Android One program which guarantees updates for two years.
20回答 すべてを表示
sim recognized but no signal!
Hello Guys !
I have the Xiaomi Mi A2 Lite,
great budget device and it was working perfectly, until one day i woke up and found that both sim cards have “no service” but i can see the operator name detected in sim settings
i’ve tried everything like factory reset and *#*#4636#*#* but no solution
could please see about that guys
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 5
2 件のコメント
I looked around and saw something about an October update causing issues with celular connectivity
さんによる
@connor2003 yes i think that too
because i updated the phone to android 9.0 few days before the "no service incidence"
i'll try to flash it and see
さんによる
コメントを追加
8件の回答
最も参考になった回答
If I were you, on the issue of SIM connectivity, the first thing I would do is call my carrier, ask them if anything happened on their end. That what you should probably do as well.
このアンサーは役に立ちましたか?
スコア 2
1件のコメント:
no I've tried them on other devices and they work perfectly !
さんによる
コメントを追加
after 2 months of struggling
i took it to the repair store
and he only flashes it with the proper firmware
and its working since
このアンサーは役に立ちましたか?
スコア 1
2 件のコメント:
Thanks for the quick answer. I tried to flash it but it didn't help. I'll try to find a repair store that fixes software
さんによる
can you please check and tell me which version of firmware you have flashed from repair shop?
さんによる
コメントを追加
Same issue here, with my A1. Since the Android 9.0 Update no signal.
Downgrade to 8 did not help.
Did you make any progress?
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
i flashed it but still no progress
i think that the 9.0 update provoked the problem on sim card reader board
its a hardware problem with this device
cuz a lot of people are having it
check this out
https://en.miui.com/forum.php?mod=viewth...
さんによる
コメントを追加
Got the same issue, did you manage to fix it?
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Same issue, no service issues on mi phone after last … such a problem phone.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Yes, I'm having the same problem. I tried every alternative. I even called customer care service to check if it was a problem with my son but they said it's active. I tried resetting everything but it didn't work. I even tried restarting the phone but it still doesn't work. Please let us know if you have any solution to this problem
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
I have the same problem
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
I have the same problem too. What things to do guys
さんによる
コメントを追加
Hope this will help you
https://okadtech.com/xiaomi-redmi-note-4...
Just go and solve your problem and thanks me later
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
MATHIL さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 6
過去 30 日: 20
今までの合計 14,963
