メインコンテンツにスキップ
HP released this ergonomic laptop (model number 15-au123cl) in October 2016. It features Windows 10 and a touch screen.
14回答 すべてを表示
Computer cant decide if its plugged in or not
I’m having a problem with charging my PC. I will have it plugged in and, for a while, everything is fine. Battery is charging, indicator light next to the plug is on. But the computer acts like I unplugged it at random times.
The battery icon says it’s not even plugged in but the indicator light is still on with the cable still attached and if I unplug it and plug it back in, it starts charging again.
I cant tell if this is a hardware or software issue, but it makes running things like antivirus or downloading updates impossible.
Google cant help me, I’m hoping someone here can.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
ベストアンサー
Hi,
Try running a battery report to check on the state of the battery.
In the report, check on the Design Capacity and the Full Charge capacity figures to see if there is a wide discrepancy between them.
If there is it may be that the battery is failing and needs to be replaced
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Faolan Kusibo さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 8
過去 30 日: 8
今までの合計 137
