メインコンテンツにスキップ
An affordable mid range laptop sold by Acer in mid 2015. This laptop comes with a Nvidia 940m graphics card, Intel i5-5200U CPU, and a 1080p display.
20回答 すべてを表示
Broken Hinge on laptop
Hey, my laptop Acer Aspire E 15 (E5-575G) has a broken right hinge. Due to this the right hand side of the screen has separated from the keyboard. This issue is starting to create an issue in the left hinge as well as it is slowly becoming damaged aswell due to the opening and closing of the lid. If you believe you can help can you please contact me on thealexmartins@gmail.com. I am able to send pictures for further explanation.hing
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
最も参考になった回答
Hi @thealexmartins ,
Here’s a link to a video that shows how to replace the hinge assemblies.
Replacement hinge assemblies are available online. Just search for Acer Aspire E 15 (E5-575G) hinge parts to get results for suppliers of the part.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
Unfortunately it's more often the plastic that the hinges screw into that fails rather than the hinges themselves. You may be able to glue it back together with epoxy (2-part) rapid glue but you will need to add reinforcement, such as by building up the glue around the crack and/or gluing a piece of fibreglass matrix board or a piece of an old de-populated printed circuit board over the crack on the outside of the case.
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
Drill holes through the lid where the original screw sockets have pulled out and reattach the hinge with screws, nut and lock washer through hinge and lid. a bit inelegant but effective and a lot cheaper than the $90 for a new lid,
さんによる
コメントを追加
回答を追加する
Alex Martins さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 4
過去 30 日: 18
今までの合計 7,186
