メインコンテンツにスキップ
PlayStation Vita, PCH-2000 シリーズの第二世代モデルです。PS Vita SlimもしくはPS Vita 2000として呼称されています。2013年秋に日本国内で発売され、2014年5月に米国で販売が開始されました。
20回答 すべてを表示
PSV - charging issue - troubleshooting ideas
Hello,
I recently bought psv slim on ebay. Visual everything looks fine and in good state.
Issue is that battery is almost empty and if you plug usb to charge (from electricity outlet with phone charger, laptop usb or power bank (already tried different usb cabels)) it’s not charging at all while psv itself on.
If you turn off the psv then it charges for about 10 minutes (always the same time) and then you can use console for some time. If you try charge longer, orange light do not show up. If you unplug and plug again the usb it shows for about 50sec and turn off (the orange light). And it’s always the same time. Old owner told me that he tried to replace batteries, but I am thinking to do this also.
I dissembled unit and find nothing unusual inside, everything looks in tact without any trash or visual damage.
PSV version is 3.65
It’s really strange that charging time is the same every time.
I tried to reset factory settings and also unplugged the battery for some time to perform physical reset.
Charger port itself looks intact and in good state on outside and motherboard side (visually) .
Maybe some overheating or voltage security measures stops charge?
Could any one suggest what else I can try to fix this?
Thank you very much :)
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 2
1件のコメント:
I also tried an official charger.
Same, you can see orange light for some time and it disappears. I am not sure if a battery charging at all. Maybe something wrong with the motherboard itself?
Would be interesting to check resistors with a multimeter, but I have no idea what discrepancies should look like. Also, just in case I cleaned motherboard. Any other ideas what to check?
さんによる
コメントを追加
2件の回答
cut it off and cut it back on
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Hi, what do you mean? To cut it off the micro usb charging port? Or unplug the battery?
さんによる
コメントを追加
Hello, are you able to measure 5V on board behind the power connector?
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Aivaras さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 5
過去 30 日: 12
今までの合計 2,873
