メインコンテンツにスキップ
Repair guides and support for your Sanyo TV.
20回答 すべてを表示
tv off then back on has screen for 3 seconds
My P42647-02 has channel display on start up for 3 seconds then blanks out, turn tv off then back on has screen for 3 seconds, however there is no back light , It seems to me that a componant is shutting down after the 3 seconds. Does this make any sence to any one John 8-25-18
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
john downing  Your model is equipped with a power failure detector. If it has a failure of the power circuit for either the analog/digital circuits or voltage failure for the LVDS it will turn of in 3 seconds. '
You can determine which circuit causes your TV to shut down by measuring the voltage on the CPU IC801. Check the diagram
The turning of at 3 seconds is not the cause but the protection for further damage to your TV.
This could be a main board as well as a power board issue. You need to let us know if you have any sound wafter your TV turns black. It is of course also possible that this is a backlight issue. You will have to remove the back of your TV and take a look at the boards. I start with the power board and check the voltage to the backlight array. If your main board does not send a signal to turn the lights on etc. you will not have the voltage going to the backlights. If you never get any sound then the focus should be on the main board and not the backlights. Post some pictures of all of your boards etc. with your question. That way we can see what you see. iFixitでの質問に画像を追加する方法
このアンサーは役に立ちましたか?
スコア 2
3 件のコメント:
Yes the tv does have sound after the picture blacks out, I forgot to mention this in my earlier statement thanks for your help I;am in the process up up loading the picts of the boards in the back, As best as I can tell there doesn't seem to be any that are burned or swell. Now I'am not tech person John Monday night
さんによる
I cant get the picts loaded they are in meda folder.
さんによる
john downing you can only add images to your question. Edit your question and follow the guide
さんによる
コメントを追加
回答を追加する
john downing さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 187
