メインコンテンツにスキップ
The Acer Aspire One model D225E is a 10.1-inch netbook that features an ultra-thin and lightweight design with a powerful battery making it ideal for everyday computing on the go. Also known as Acer Aspire One D255E-13639.
I shorted out my usb port
tyler.norton82 less than a minute ago
I shorted out my laptop, I was trying to plug my headphones in the dark and it went into the usb port. When I went to turn it on, the fan starts the power light turns on for about 5 seconds, but the screen doesn't turn on. Then it shuts off and tries to start again, over and over. U my lap top is a Acer aspire e15 e5-511-c0pc. I'm not to familiar with laptops, I have once taken it apart to replace the hard drive. Can I take out the memory and hopefully fix it?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
Unplug remove battery hold down power button for 30 seconds grab a door knob to make sure to discharge any static from your body tske paper clio and look i side usb and strighten all the pins. That should work if n o t replace usb port its shorted out
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
@retlaw132002 thank you for your solution comment.I really appciate
さんによる
コメントを追加
回答を追加する
Tyler Norton さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 6
今までの合計 448
