メインコンテンツにスキップ
Microsoft Corporationが設計したXbox One Sは、2016年8月に発売されました。Xbox One Sは、Xbox Oneを再設計した製品です。
20回答 すべてを表示
I spilled coffee in it about a month ago?
About a month ago, give or take some change, I was drinking coffee out of a red Solo cups, and for whatever reason, my apparently geniusness decided to put the cup on top of my Xbox. It spilled into the fan vent, I kinda panicked but since nothing really happened right away, I figured most of the liquid missed and hit the floor, well... More that what I thought got in there did just that. Long story short, I'm kinda stupid, took it apart, cleaned out the coffee with a rag (it had a lot of sugar, so I know that didn't help) and put it back together, which, in turn, made it worse. Now I'm lucky if I can even get it to load the initial Xbox screen. Sometimes I'll get all the way to my profile, then it'll shut itself off. Now I just use it as a charger box. Is there ANY way it might be salvageable, or is it the end for ol' sweet Chelsea? I also let it run WITH THE COFFEE IN IT, for about an hour, then it shut itself off. I still haven't put her back together completely, either. I still have hope, and I'd appreciate ANY help, even if it's just breaking bad news to me.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
1 件の回答
最も参考になった回答
does it show any signs of corrosion, if so use isopropyl alcohol stronger the better like 90 % range and a toothbrush and clean the corroded areas. where abouts are you located
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
回答を追加する
DonVhanDüde さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 4
今までの合計 985
