メインコンテンツにスキップ
2017年1月16日に発売されたNvidiaの単体ゲーミングコントローラーの修理ガイドとサポートです。
Nvidia Shield Controller (2015) touch buttons replacement?
So a while ago my 2015 1st gen Nvidia shield front touch buttons stopped working, and I thought it was a bad 12-pin cable. It turns out it's the touch buttons (nvidia button, home button, back button, and play button) that stopped working. I have searched far and wide for a replacement but haven't found anything. Can anyone direct me to where I can find one?
Thanks for responses in advance :)
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
1 件の回答
Mine also stops working but it’s a firmware issue. Recently I found out, when I cut out the power by disconnecting the battery from a 2015 controller and plugged back in everything works like a charm until I reboot or shut down the console. So I made a workaround. I drill a hole on a controller and connect a switch to the battery. It was annoying the old way now I just hit the diy switch off and on and everything works fine
Regards
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Matrucious さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 6
過去 30 日: 14
今までの合計 1,606
