Screen replacment Model A1370
Will a macbook air 11 inch model A1465 screen fit on a macbook air 11 inch model A1370?
この質問は役に立ちましたか?
お持ちのデバイス用の修理ガイドとパーツ一覧とアンサーフォーラムにアクセスする。
この質問は役に立ちましたか?
2010-2012 (A1370 for 2010-2011 and A1465 for 2012) screen assemblies are cross compatible with each other, 2013-2015 (A1465) screen assemblies are cross compatible. You will need a 2010-2012 screen if your model is a 2012 model.
The LCD panels work across all models if you are just replacing this rather than the whole lid, the only difference between earlier and late models are the camera cable length, WiFi cable length and LCD cable type (earlier are gold, later silver, but both interchangeable).
このアンサーは役に立ちましたか?
2010 A1370 and 2013 A1465
My 2013 is totalled and the screen on a 2010 is in need of changing.... can I use the top case complete from the 2013?
過去 24時間: 0
過去 7 日: 3
過去 30 日: 9
今までの合計 1,013
