メインコンテンツにスキップ
iPad Air Wi-Fi +セルラーモデル、モデル番号はA1475でスペースグレイかシルバーのカラーが選べ、容量は16/32/64/128 GBがあります。
20回答 すべてを表示
USB device not recognised. Win 7 home premium.
I have an Ipad air LTE. was produced to me as DISABLED as they put the wrong password in too many times. The ipad charges through the port but is not recognised by windows so i can't do much to get into the device. Tried on several machines so it isn't computer related. Have not got another lead to try, but my ipad mini works fine connected to same computers, same lead. Any suggestions?
Sounds like an electronics repair job i *think*. Thoughts?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
5 件のコメント
Have you installed iTunes? Have you tried different cables?
さんによる
Yes i have, latest version and no i havn't. The mini works so it's not the cable
さんによる
Cheers mate, yes it goes into recovery mode but as soon as it is plugged into the pc the USB message comes up saying it can't recognize the device, so that's where the world ends lol
さんによる
@smythie17 Hello, does anything show up on iTunes when you plug it in?
さんによる
no it does not
さんによる
コメントを追加
2件の回答
ベストアンサー
Hi @smythie17 ,
Try forcing the iPad into the recovery mode and see if this works at all.
1. Turn off the iPad
2. Launch iTunes.
3. Plug the USB cable into the computer.
4. Press and hold the Home button down and plug the other end of the USB cable into the docking port.
Do not release the Home button until you see the picture of iTunes and plug
5. Release the Home button.
6. Hopefully iTunes has detected that the iPad is in the recovery mode.
7. Select Restore iPad
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
Go into Device Manager
See if you have any devices with error messages
Remove these from Device Manager
then scan for hardware changes.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Did that as well, just comes up with same error message when connected
さんによる
コメントを追加
回答を追加する
Gary さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 2
今までの合計 578
