メインコンテンツにスキップ
A BTX computer introduced in 2006 using a Intel LGA775 socket processor. The 5150 is identical to the E510.
black screen on monitor Dell Dimension 5150
i have replaced the sata cord from hard drive to the mother board mother board light is solid green also but still has a black screen on the monitor the monitor is fine been tested everything been checked but the hard drive has not been replaced the post code numbers 123 light up solid green also power button lights up solid green but number 4 does not light up it is a Dell Dimension 5150/E510
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
ベストアンサー
@bk555 the 4th light off is a generic error message:
Another failure has occurred.
• Ensure that the cables are properly connected to the system board from the hard drive, CD drive, and DVD drive.
• If there is an error message on your screen identifying a problem with a device (such as the floppy drive or hard drive), check the device to make sure it is functioning properly.
• The operating system is attempting to boot from a device (such as the floppy drive or hard drive); check system setup to make sure the boot sequence is correct for the devices installed on your computer.
I'd start with checking to see if you can access the BIOS. It is possible that you drive may have failed.See if you can run the Dell Diagnostics
1 Turn on (or restart) your computer.
2 When the DELL™ logo appears, press <F12> immediately.If you wait too long and the operating system logo appears, continue to wait until you see the Microsoft® Windows® desktop. Then shut down your computer and try again.
3 When the boot device list appears, highlight Boot to Utility Partition and press <Enter>.
4 When the Dell Diagnostics Main Menu appears, select the test you want to run.
Let us know what you get.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
just me 55 さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 12
今までの合計 473
