メインコンテンツにスキップ
Wi-Fi版iPad Mini 2の修理ガイド。2013年10月22日発表、11月12日発売。iPad mini 2はiPad mini Retinaディスプレイモデルとして知られ、iPad Airのすべてのピクセルを7.9インチに小型化しました。
20回答 すべてを表示
Strip of digitizer unresponsive
I replaced the digitizer on my iPad mini 2 but I’m having a problem. There is a strip, approximately 1” across the top, that is not responding to touch. The screen is fine and everything else is working but nothing happens when I touch within this strip. Is there a problem with the digitizer or did I do something wrong?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
ベストアンサー
Most likely it is a faulty digitizer (probably a weak solder joint on the flex). I would try re-seating the digitizer connector to the motherboard, just to make sure it's not loose. If you still have issues, get a replacement digitizer.
If a replacement digitizer has the same problem, you should look at the digitizer socket on the board.
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
Thank you!
I just re-seated the digitizer and checked the pins so see if anything looked bad but they seemed to look fine. Now less of the screen works and it has ghost touch which wasn’t happening before. So my next step is the new digitizer. Should I get the Front Panel Full Assembly or just the Front Panel Glass? Your website says the home button is not included but easy to switch out the new one. Are there instructions for that?
さんによる
コメントを追加
回答を追加する
Danielle Misciagna さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 511
