メインコンテンツにスキップ
The PowerShot S110 has a 12.1 Megapixel High-Sensitivity CMOS sensor and DIGIC 5 Image Processor, 12-bit multi aspect RAW+JPEG, 24mm Wide-Angle, f/2.0 lens with 5x Optical Zoom and a sleek pocket-sized body.
6回答 すべてを表示
I read that a microswitch may be missing
I have a S110 that doesn't power on, battery is good. I've read elsewhere that there should be white micro-switch under the battery cover that may be missing. Is this a DIY repair, urban legend?
Thanks,
Alan O.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
in case you haven't tried you can poke around to see if there is anything hidden under a sticker
このアンサーは役に立ちましたか?
スコア 0
2 件のコメント:
what sticker?
さんによる
there could be a sticker, perhaps plain colored in the battery cover hiding the switch as this a common way to hiding screws, as i am not familiar with this camera there isn't much i can tell you.
さんによる
コメントを追加
回答を追加する
Alan O さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 4
今までの合計 198
