メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Motorolaは2015年10月下旬にDroid Turbo 2を発売しました。モデル番号はXT1585です。
USB connection not working
The data pins on my phones USB don't work so I can't fast charge or use the USB to connect to my stereo. Can it be fixed?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 4
1件のコメント
Bought a new phone, Verizon told me it could not be fixed, so after buying a new phone I started to see if someone could fix my old phone. Well I want to thank you for this info, it did work for me and my XT1585 MOTO is as good as new. Thanks again Wade
さんによる 共有
コメントを追加
3件の回答
ベストアンサー
My phone started this about three years ago. Internet search found it’s a common problem with the Turbo 2. Port is poorly soldered to the board. Found a company that could repair it. They even had a YouTube video of him doing the repair. Then I found the the phone has an inductive charger, so I’ve been using it ever since. I recently had to replace the battery. Thought while I was in there I’d solder those connections myself. That’s when I realized why he was using a video microscope. The connections are tiny. There are five of them in a row and they are all in about a 3/8 inch space. I had to put on a pair of reading classes and look through the lighted magnifying glass I have mounted on my desk. I didn’t have a soldering tip small enough. In fact I’ve never seen one small enough so I wired a needle to the tip and went at it. The needle just wouldn’t transfer enough heat to melt the solder so I gave up and finished the battery install.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
最も参考になった回答
Have you tried another cable? If so, have you tried cleaning the pins with isopropyl alcohol? I like to use a Q-tip.
Do a visual inspection of the port. It's possible that you have lint jammed in there. A toothpick or tweezers can work to clean it out.
このアンサーは役に立ちましたか?
スコア 4
1件のコメント:
I tried cleaning and a different cord it is just the data pins that don't work
さんによる 共有
コメントを追加
I had the same problem about 5 times now and Verizon has replaced my phone under warranty. Loose charger port is a “known issue”
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Wade さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 2
過去 30 日: 19
今までの合計 2,207
