メインコンテンツにスキップ
Released in 1999, the Braun Exact Power EP100 is an electric beard and mustache trimmer. It has an internal rechargeable battery.
3回答 すべてを表示
Disassempling of the Braun EP100...?
How do I disassemple it? It is impossible without destroying the halfshelves that covers it........?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
2 件のコメント
Did you check for a replacement cost from Braun, I just replaced my unit that was over 300 bucks for about 50. Series 7
さんによる
Finally I managed to open and repair it.
it felt from my hand, and refused to work anymore.
So decided to open and check the issue. I had to force a bit , nothing to complicated, but the clips were very tied, thats why anyone is scared to insist... Finally it was the negative pin of the battery that was cutted from the board, so just resolder it to the board, and it was good to go :)
さんによる
コメントを追加
2件の回答
最も参考になった回答
@nlzhlm the EP100 actually is a Braun 5601. Yes it can be disassembled without breaking it. Here is the SM Braun EP100 service manual that shows you how to work on it.
このアンサーは役に立ちましたか?
スコア 4
コメントを追加
I got the same problem, I need to open it, but arrived to the point where the cover is strongly held. I dont want to force to dont destroy it. did you finally manage to open yours??
Thx
Edit:
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Niels Holm さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 3
過去 30 日: 8
今までの合計 2,023
