メインコンテンツにスキップ
モデル番号A1419 / EMC 3070 / Mid 2017 / 3.4, 3.5もしくは3.8 GHz Core i5もしくは4.2 GHz Core i7 Kaby Lakeプロセッサ (ID iMac18,3) / Retina 5Kディスプレイ。システムは類似しているため、修理ガイドについては旧モデルのiMac Intel 27インチ Retina 5Kディスプレイ (Late 2014 & 2015) を参照してください。
293回答 すべてを表示
The New iMac 27" 2017 model can upgrade ram and ssd?
Hi, just wondering the new iMac 27" 2017 model can easy upgrade the ram and ssd hard drive? Think the get the lowest specs and upgrade myself. Got any issue from fusion drive to SSD? Thanks for advice.
Update (06/22/2017)
But the main point I need the OS & software run it faster instead of need a largest storage. Just wondering is easy to change it to SSD if the specs is Fusion Drive not. Or get the SSD specs is better, so if need to upgrade in future is still feasible.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 14
2 件のコメント
Sorry Simon didn't see your post.
Then you want the largest PCIe SSD model you can afford. It will be the fastest! Great for running your OS & App's and hosting the OS & Apps cache & paging files. Then use an external Thunderbolt HD or install your own internal SATA drive (dual drive config).
While a Fusion Drive is in truth a dual drive setup, Apple does not offer a very large SSD so it may not offer the speed you are looking for and even if you broke the Fusion Drive set to be discreet drives you might find the limited space of the SSD won't be enough to hold your OS, Apps as well as what the OS & Apps need for cache & page files.
さんによる
Thanks Dan!! Appreciate your reply and the answer is helpful :)
さんによる
コメントを追加
15件の回答
ベストアンサー
The new 27" iMac's do have the same access door in the back as the last model, as seen here: iMac Intel 27" Retina 5K Display RAM Replacement.
Upgrading the PCIe SSD requires almost completely tearing down the system as seen here: iMac Intel 27" Retina 5K Display SSD Replacement. So far we don't know if you buy a HDD model only if the PCIe SSD slot and the sundry parts are even present as Apple has in the past has not populated the logic board (Update: All of the 27” systems to 2019 have the SSD slot) This is the case in the 21.5" model as you can see here in the IFIXIT teardown:: iMac Intel 21.5" Retina 4K Display 2017 Teardown
So I would recommend you get the PCIe SSD based system and I also recommend you get the largest SSD you can get as Apple is still the only source for their custom SSD.
Then if you want to add more storage (HDD or SSD). You can then add in the SATA drive later.
Just keep in mind these 'Thin Series' systems are a bear to open so make sure you follow the IFIXIT guides to the letter and use the correct tools as you can easily damage the display in the process of taking the display assembly off which would be a very expensive opps!
Update (06/19/2017)
The term 'Hard Drive' is passé, instead we use terms HDD or HD for the older traditional spinning disk drives or SSD for the solid state drives. If you don't know which then just use the term 'drive'.
So yes, its best to get the SSD only model or the Fusion Drive model which has both a HDD and SSD fused together as one logical volume (two drives seen as one).
As to the PCIe SSD its self, Apple does not sell it as spare (only as an exchange of the same size) and the parts houses which buy compete systems and tear them apart for the parts charge premium prices! So get the largest PCIe SSD you can afford now.
As I stated if you got the PCIe SSD only system you would still have a spare SATA drive bay (3.5" is what we expect here until IFIXIT does the teardown to verify) which will allow you to add in your own drive which could be a HDD or SSD. But! It's still a bit of work as you'll need to get the proper SATA/Power cable harness from Apple and as you are putting your own drive in you'll need this: OWC In-line Digital Thermal Sensor for Hard Drive Upgrade for 27" iMacs 2012 and Later as unlike the custom Apple HD drives you need to add in a thermal sensor for the system to work properly.
If you get a Fusion Drive'd model you will have a dual drive system so you would need to swap out the SATA drive to a larger one if that was your direction later on.
Frankly, Apple is really making it harder to do any drive upgrades these days with the 'Thin Series' iMac's. If you can, get what you want now for drive storage.
Given the risks of damage and the amount of work to even get into the system it's not something I recommend for someone who has not opened one of these newer 'Thin Series' systems before.
iMac Intel 27" Retina 5K Display メモリの画像
ガイド
iMac Intel 27インチ Retina 5Kディスプレイ メモリの交換
難易度:
簡単
1 - 5 minutes
iMac Intel 27" Retina 5K Display Blade SSDの画像
ガイド
iMac Intel 27インチ Retina 5K Display Blade SSDの交換
難易度:
難しい
2 hours
iMac Intel 21.5" Retina 4K Display (2017)の画像
ガイド
iMac Intel 21.5"Retina 4Kディスプレイ(2017年)の分解
難易度:
中レベル
このアンサーは役に立ちましたか?
スコア 10
2 件のコメント:
Thanks for advice! So if I place order is better to get the SSD hard drive instead of fusion drive right? By the way, as you mention you recommended to get the largest SSD from Apple, so is better like don't upgrade ourself? The upgrade SSD price from Apple is reasonable?
さんによる
Correct get the SSD only model and get the largest SSD you can afford now.
Apple's SSD is custom and very expensive if you try getting one on the open market as they can only be gotten from a parts system. Don't even think of doing the blade SSD upgrade later its just not worth the risks. I wouldn't waste my money buying q the Fusion Drive system either as the you'll end up with a very small blade SSD (128 GB) the straight PCIe NVMe blade SSD will give you much better performance.
If you need gobs of storage go with an external Thunderbolt RAID 0 drive it will be faster than the internal SATA III HD. While adding a HD is possible, I would wait till the warranty period has ended as Apple has refused servicing systems which are not factory. Then if you really want an internal drive do it then. I think you'll find the external RAID drive will be superior.
さんによる
コメントを追加
Just for the record, I got the 27in with the 512GB SSD and it is blazing fast (think NVMe speeds). I would recommend the SSD over the Fusion Drive as you can't (or shouldn't due to Apple Care concerns) upgrade the internal system drive after purchase.
このアンサーは役に立ちましたか?
スコア 7
4 件のコメント:
Thanks Jack!!
さんによる
Agreed! A straight SSD model is faster than a Fusion Drive model.
さんによる
How much memory?
さんによる
Minimum is 8GB, upgradeable to 64GB. I got a 32GB kit to add to the default 8GB for 40GB total.
さんによる
コメントを追加
Agree with getting an Apple SSD to start, it's the fastest. The SSD in the Fusion drives is NOT as fast as the SSD only models. I have a late 2013 model that started as Fusion, replaced the HD with SSD myself, not much difference in speed gain at all. The PCIe/NVMe connection is a game changer in speed.
Just ordered a loaded 2017 iMac, except I will be adding the RAM myself. This one has the 1TB Apple SSD and NO Fusion this time.
From personal experience and my buddy's iMac:
Mine is a loaded late '13 27" iMac....I installed a Crucial 2TB SSD.....i7 3.5 and 32 GB RAM.
My buddy has a refurbished late 2015 27" iMac, i5 3.2 and 16 GB RAM.
I use a lot of Lightroom, Photoshop & FinalCut Pro daily for work. Tested a bunch of stuff on his and it's faster than mine without lag. For example, in Lightroom, 8 large RAW images export to Photoshop in exactly 1/2 the time on his than mine. On the Black Magic test, his is 3 times faster than mine. In practice, his is twice as fast and adjustments in Lightroom happen in real time instead of a second or two lag.
このアンサーは役に立ちましたか?
スコア 4
1件のコメント:
So true! It's the drives I/O that's the killer when working on large projects like RAW images. RAM is important too here.
さんによる
コメントを追加
At this point its easier to just buy an external 4tb drive and just use that via Thunderbolt 3 than go thru the hassle to upgrade the HDD.
このアンサーは役に立ちましたか?
スコア 3
1件のコメント:
Up to a point I do agree with you!
Sadly, a traditional SATA III HD within a TB3 enclosure won't be as fast as the PCIe mounted SSD. You would need to RAID the drives and ideally you would want SSD's in the external enclosure.
So having the internal SSD hosting your OS, Apps and cache/paging files, then have your RAID'ed external drive for your bulky data makes the best sense! That way you leverage the best storage by usage.
さんによる
コメントを追加
I always see people say you shouldn't do this if you've never done it before. How does anyone ever do it the first time then?
このアンサーは役に立ちましたか?
スコア 3
4 件のコメント:
Lets be clear here we don't throw people into the water a mile out to shore and expect them to swim without the skills to even swim yet!
You work on simple projects working up to the bigger jobs, honing ones skills.
さんによる
Because if you have a mishap and break the screen the machine may be a total loss. Watch this if you haven't already:
https://www.youtube.com/watch?v=9-NU7yOS...
さんによる
LOVE THAT ANSWER!
I repair things for a living and 90% of what I fix, I've never done before! I haven't even HELD an iPhone 12 Pro Max yet, but I can't wait for someone to walk in my door and ask for a charging port replacement, screen or button assembly.
Some people have that *bug* to fix things and I'll bet that 90% of people that frequent iFixit have a natural inclination to repair, restore, troubleshoot and solve problems.
さんによる
I frequent an Apple fansite and the folks there love to scare people out of fixing their devices. It's called mac rumors and every blue moon, I'll forget where I am and ask a question- and lemme tell you- If they don't know THE answer, they're still gonna give you THEIR answer...
"Why would you want to do that?"
"Did you do a hard reset?"
"Are you using a genuine Apple charger?"
"Apple says 8GB is the max RAM"
and my all-time favorite: "Don't mess with it, take it to the Genius Bar"
There used to be intelligent life on MR, but guys nowadays just post for post's sake. Yeah, I once asked what the fastest CPU a 2017 iMac could support and the next morning there was 5 PAGES of how nonsense dedicated to how it's not worth the RISK, COST, or TIME. I explained how I had a broken iMac and wanted to install the best CPU it could take, but even that fell upon deaf ears: "How do you know it's the CPU?"
さんによる
コメントを追加
I'm sorry...I don't speak english very well and If I understand well, for a future upgrade, it is better to buy the SSD version instead of the one with FusionDrive. Right?
このアンサーは役に立ちましたか?
スコア 1
4 件のコメント:
Just like Simon:
Get the SSD only model and get the largest SSD you can afford now.
さんによる
Hi Dan. I just wanted to ask, if i buy the fusion drive model, can i add a SSD later on? I mean does 2017 Imac support double disk drives? In this particular case an SSD plus a Fusion drive?
さんによる
I don't think is work. should be can put 1 HD in iMac only. If you planning to upgrade SSD, follow the public answer you should get a SSD version instead of Fusion drive. And received a news from Mac rumors the New Apple File System Coming in macOS High Sierra Won't Work With Fusion Drives too
さんによる
Correct Simon! Best to go full out with a straight SSD system and get the largest you can afford!
Then Later decide if you really need still more storage and if it should be internal or external. I recommend you go externally! With a nice Thunderbolt RAID 0 solution!
さんによる
コメントを追加
I'm not sure if anyone is still following this post but I finally made the leap and all seems to be working perfectly. This is my first time doing any type of upgrade but the ifixit instructions were clear and the OWC kit helpful.
I bought my mid year 2017 iMac brand new but with little of the bells and whistles at the time.
For this project, I went from i5 to i7 processor, swapped 512 flash storage for 2TB Aura Pro X2 and then added OWC Mercury Extreme Pro 6G for an SSD.
I did not have any SATA drive before so the toughest part was finding the correct SATA cable to add to my mother board.
My question: Now that everything is working, do I need to redirect any major functions to different areas. Point some things to the new SSD that machine did not have before etc? I'm not very knowledgable in that area.
Thank you for any insight. John.
このアンサーは役に立ちましたか?
スコア 1
3 件のコメント:
John - Which drive is hosting your OS? Ideally you want the PCIe/NVMe drive to be that drive and you want to also place your apps on it so you leverage the speed of the blade drive.
Depending on your workflow as an example video and music production or image art photography you'll won't to use part of the blade SSD as your current project work space and use your internal SATA drive as the area which holds your finished work and other content files (i.e. iTunes music and vids)
さんによる
Thanks Dan, I just rebuilt everything from scratch and it appears all is going on my Aura Pro X2. Nothing is showing up on my 4TB SSD which is why I wanted to ask now. I'm not sure about how to direct traffic. What should park where. I also saw some mention of telling the SSD Thermal sensor to actually turn on. I'm not clear if that was automatically sniffed out by the machine. I appreciate your input.
さんによる
Also since I did not have any SSD before, is there a way to take advantage of any fusion functionality?
さんによる
コメントを追加
So, as I see this, could be synonymous but a Samsung SSD 960 EVO 1TB, M.2 function. It also has PCIe 3.0 x4 and NVMe memory. It is extremely fast and inexpensive. Am I wrong?
このアンサーは役に立ちましたか?
スコア 0
5 件のコメント:
Sorry @dukemax - While the Samsung 960 EVO M.2 drive is a great drive, it won't fit into the custom Apple SSD connector. Your only choice presently is using an Apple PCIe NVMe x4 blade SSD or install a slower SATA III (6.0 Gb/s) 2.5" SSD replacing the HDD.
さんによる
Retail:
Amazon:
* Samsung 960 PRO Series - 512GB PCIe NVMe - M.2 Internal SSD (MZ-V6P512BW) $339.99
* Samsung 960 PRO Series - 1TB PCIe NVMe - M.2 Internal SSD (MZ-V6P1T0BW) $619.00
* Samsung 960 PRO Series - 2TB PCIe NVMe - M.2 Internal SSD (MZ-V6P2T0BW) $1,297.99
Apple:
* 512GB "SSD" $200
* 1TB "SSD" $600
* 2TB "SSD" $1400
Buying the 512GB or the 1TB drive you come out ahead or even. Open that iMac up and install a 2.5" SSD.
You can now create a fusion drive with two SSDs. Should be plenty fast. Not sure if there will be a cable from the motherboard to the empty spot where the 2.5" drive fits. A temp sensor and harness can be purchased from OWC in any case. I am assuming Apple is using Samsung flash SSDs for their iMacs.
さんによる
Well, you got a few errors here... The Samsung M.2 drives won't fit or work in your iMac. Yes, Apple contracted Samsung to make the custom blade SSD's for them to Apples specs. But these are not the same as the M.2 drives!
As for using a 2.5" SSD sure you can! And it can be the Samsung drive. But! And thats a very big But! The data rate from the custom Apple SSD is vastly faster (5 GT/s) than the SATA III (6 Gb/s)!
The last point here is you really can't use a dual SSD setup in a Fusion Drive set.
The bottomline here is your numbers show it makes sense to spend the money upfront for the better Apple custom blade SSD's than to slide in a much slower 2.5" SATA SSD. Which I agree!!
It makes the argument to just do it day one and then later go with an internal SATA HDD or better stick with an external RAID'ed drive solution if you really need more deep storage.
さんによる
You surely can use a dual SSD setup in a fusion drive set. You can even you 2 SSDs and 3 external drives if you like. You would just need to build the CoreStorage container with the drives that you want to fuse. You can even use USB sticks if you like, it is really just LVM.
さんによる
@pcworks_jason - I think you have things confused here. A Fusion Drive is a unique two drive config which is a SSD and a HDD 'fused' The SSD is acting as a cache for the HDD. This must be internal of the system and you can't use two SSD's as you'll confuse the OS. A dual drive config thats not setup as a Fusion Drive is quite workable! As an example my own system has a 512 GB SSD and a 1 TB HDD. Each is discreet (I can see them both on my Desktop unlike a Fusion Drive set will only show the HDD hiding the SSD)
What you are really describing are RAID sets. This is were two or more drives are inter-connected to offer faster I/O or mirroring. Review this great writeup: Advantages and disadvantages of various RAID levels
さんによる
コメントを追加
I've got an iMac 5k 2017 with 2tb fusion drive, it is possible in the future add an SSD instead of the 3,5 HHD? I mean, how the system will read it? As a fusion drive or as two separated internal drives? Will it be significantly faster?
Thanks a lot
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
A Fusion Drive based system uses 2 drives a HDD and a SSD which is 'fused' to look like a single drive.
Your system supports two drives a 3.5" HHD and a custom blade SSD. It only has two drive ports which with a Fusion Drive setup are in use.
So adding a drive (replacing) will require you break the Fusion Drive you currently have to free up a drive port.
Ideally, the largest SSD (Custom blade drive) you can get will offer the best performance! The SSD used in a Fusion Drive is quite small so its what will hold you back if you alter the 3.5" drive (with either a HDD or SSD).
So if we look at which is the better performance between a HDD Vs a SSD only system the SSD based system (SATA) will offer better performance by a long shot! But the cost of the SSD drive is about four times (1 TB Seagate HDD $60 Vs 1 TB Samsung $250 US).
Now the SATA interface is holding us back even with the latest SATA SSD's! Which is one of the reasons Apple went with a custom PCIe/NVMe type of SSD interface. SATA III (6.0 Gb/s) Vs PCIe/NVMe x4 (8 Gb/s).
To help make the cost to performance ratio better Apple intro'ed the Fusion drive by using a small SSD as a cache drive to the HDD. Similar to a hybrid SSHD like Seagate's FireCuda drive which had the cache as part of the drive Vs independent in the case of a Fusion Drive.
As you've already bought your system I would leave it alone and look at getting an external Thunderbolt-3 RAID-0 SSD drive and configure it up as your boot drive. The Thunderbolt-3 port is faster than the internal SATA port and very close to being as fast as the PCIe interface. As we are RAIDing the SATA SSD drives will offer more performance as well being very close to the same performance as Apples 1 TB blade SSD drive. Yes, this is more costly than if you had bought a SSD only based system from the get go. but you can't improve what you have without risk and the cost of the needed SSD now is quite high (in fact more expensive than what I'm recommending)! The other option is what Amir Neshati above did sold his system and got the SSD model.
さんによる
コメントを追加
Good evening,
I do not understand everything but:
1- can we change the hard drive 3.5 internal not a 2.5 SSD with a size adapter?
2- must we necessarily remove the ssd behind the motherboard if it is possible to put an SSD in place of the hard drive 3.5?
Thx! ;-)
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
I have successfully upgraded my iMac (Retina 5K, 27-inch, 2017) with a 2TB Samsung 970 EVO NVME SSD. Please see post below for full details. The upgraded system is working flawlessly, with great speed improvement.
https://forums.macrumors.com/threads/ima...
Thanks.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Thanks for sharing it in enormous level of detail. Have you managed to solve the 970 evo PLUS write speed issue? I posted a detailed question in the forum you linked to: https://forums.macrumors.com/threads/ima...
さんによる
コメントを追加
Replying to this despite it is super old
A 2013 And 2014 imac only uses 2 lane PCIe where as 2015 and above uses 4 Lanes?
Max Speed for 2 lanes is around 800 transfer speed where as 4 lanes can easily get into 2800 ranges
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Best to review this great guide! The Ultimate Guide to Apple’s Proprietary SSDs
さんによる
コメントを追加
@danj Hey Dan, I'm late to this comment section but hoping you see this! Really wish I read some of this before purchasing my computer because I unfortunately purchased the Fusion Drive.
I now am in the process of upgrading my iMac to the max I possibly can and have decent money to spend. I have already upgrade to 64gb RAM (really easy obviously) and was getting ready to upgrade to i7 processor as well as a second internal hard drive. I watched a video on youtube of a guy who did this, but realized he also said at the beginning he bought the version with the SSD and not the Fusion Drive.
So being that I have the Fusion Drive version, and I hypothetically want a second internal hard drive, could I replace my current Fusion Drive with an internal SSD as well as adding a second SSD hard drive, the Crucial 2tb one was the one mentioned in the video and I was getting ready to purchase.
I appreciate your help, thanks!
このアンサーは役に立ちましたか?
スコア 0
3 件のコメント:
@jforrer0229 - Lets back up here. If you have a Fusion Drive setup you have no means to add another drive without taking something else out! You only have two storage ports: PCIe/NVMe SSD blade and 3.5" SATA III HDD/SSD.
So what is the planned usage of your system? Upgrading it to 64GB is a bit much for a i5/i7 system! Are you doing music or video editing or something else that needs this much. You may want to return some of it if you can. Upgrading the CPU from an i5 to an i7 would be the first thing I would do. But do keep in mind the limitation of the dedicated graphics this older system has. Maybe you'll want to rethink your direction here.
Most of the collage students which are in school studying music and video mostly work with 32GB of RAM and instead put more into their internal storage. 1 TB PCIe/NVMe blade SSD and a 2 or 3 TB of HDD or SSHD in their i5/i7 systems the pro's go with the newest i9 iMac's or iMac Pro systems as these have more powerful CPU's that is better for their needs.
With the availability of the new Mac Pro some are seriously thinking on getting them (working pro's).
さんによる
@danj Thanks for the quick response, I do appreciate your time.
I think I can easier sum up my goal with the video I was referencing, which I am sure you have seen before. Here is the link: https://youtu.be/knMM9dRwIH4
I essentially want to replicate this is exactly, the only problem being he mentions in the beginning of the video he bought it with included SSD. I didn’t watch or think about doing this until after getting my Mac. I’d rather upgrade my current computer than go through the hassle of selling it and buying another, and I have a bunch of Amazon gift card money I can purchase the parts with. At first I was only going to get the processor but being I need to open the computer up I would rather only do that once and upgrade anything and everything I could in one shot.
I do professional and advanced music production and could use the specs, and want this to handle my projects for years to come, but regardless I just want as close to a maxed out iMac with what I have that I can.
さんによる
OK, still think you went overboard with the RAM ;-}
So focus on the CPU (i7) and the blade SSD (stick with a real Apple blade SSD)
Get the 1 TB blade Samsung SSPOLARIS SSD. Don't mess with anything else
BeetsTech - 1 TB Samsung SSPOLARIS SSD
TheBookYard - 1 TB Samsung SSPOLARIS SSD
If you watch the YouTube vid you'll see he started off with the 1TB blade SSD system.
You'll need to first backup your system and then break the Fusion Drive set. As far as the SATA drive you might want to look at just going with an external RAID drive setup for your work drive. Just using the internal SATA drive (1 or 2 TB SSD) for your current project. Many Pro's have very large sample libraries and they often want access to their older work which is why they want a much larger external drive and have a second one which is a synced version (weekly) which they store off site in a fire-proof safe.
The blade SSD will hold your macOS, Apps and nothing else! The rest of the drive is for cache & scratch space.
さんによる
コメントを追加
Hello, I am using iMac 2017 18.3 with 1 TB Fusion Drive I want to upgrade HDD to SSD and NVME also.
Please help me. thank you
このアンサーは役に立ちましたか?
スコア 0
3 件のコメント:
@Gayan Pradeep Just follow these two guides:
iMac 27インチ 2017 ハードドライブの交換
iMac 27インチ 2017 Blade SSDの交換
The tools & parts info is within the guides
さんによる
Thanks For the reply
As well as I want to know more that is I am a graphic designer and working full day in my office. when I upgrade, if I use Nvme m.2 1TB to run apps like adobe premiere are there generate any Heating problem. there are another 2017 iMac but it is SSD Version according to my knowledge is not Nvme upgraded. this time I want to upgrade above mention 2 unit (SSD& Nvme) which is the better ?
Only SSD Upgrade ?
Or SSD & Nvme Upgrade ?
さんによる
@Gayan Pradeep - If your work matters you'll want to stick with the custom Apple blade SSD or the OWC bade SSD. I wouldn't use an M.2 SSD in an iMac. Apple has a bunch of additional data lines in their SSD's and the blade interface the M.2 SSD's and the adapter can't access or even know how to.
Think of it this way you need a metric nut for the bolt that holds your cars steering wheel but all you have is a slightly larger english nut which only captures about half the threads, are you willing to accept the risk when the nut jumps off under stress? I think not! Get the real or OWC blade SSD
Your HDD is SATA based so replacing it with a SSD won't change the interface from what it is. A PCIe/NVMe 4 lane blade SSD is the best SSD you can put in.
I would leave the 1TB HDD alone, and only replace the blade SSD to as b ig a SSD you can afford, hopefully 500GB or 1 or 2 TB. Using the blade SSD as your boot drive and holding your Apps, then leave the rest to your current project . Moving off the project when done to the HDD. Ideally you want to have 256GB if not more left unused for the OS and Apps to leverage for caching & scratch space.
さんによる
コメントを追加
for 2017 iMac to have larger storage and faster system, can you install PCIe SSD on the back of the logic board to run MacOS and install i.e 4TB HDD in SATA to store data?
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Simon Yong さん、ありがとうございました!
統計データ:
過去 24時間: 6
過去 7 日: 32
過去 30 日: 86
今までの合計 117,296
