メインコンテンツにスキップ
The Toshiba Satellite L675D-S7016 is a laptop with a 17.3" screen released in 2010. The serial number for this specific guide is YA364457K.
6回答 すべてを表示
Space bar not working
My space bar didn't work so I replaced the keyboard and it still doesn't work. Any suggestions?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
1件のコメント:
Hi,
Just curious. Try using a USB keyboard and see if that works OK.
That way will prove it is either a hardware or a software problem
さんによる
コメントを追加
2件の回答
Hey,
There is a possibility when you replaces the KeyBoard it was a malfunctioning KeyBoard. Its rare, but it happens.
I would say use a USB Keyboard and see if the spacebar works on that. and if it does, its just the keyboard. If it doesnt then it is most likely a software issue. and we can work form there.
Replacement Guide: Toshiba Satellite L675D-S7016 Keyboard Replacement
Thanks.
Keegan
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
I took it into a local repair shop and they found out that it was a driver conflict that was causing the problems.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Dennis Nelson さん、ありがとうございました!
統計データ:
過去 24時間: 10
過去 7 日: 10
過去 30 日: 10
今までの合計 1,082
